Keine Steckachse vorne, hier die vollen Specs:
RAHMENM5 hydroformed tubing, 29" geometry, tapered HT, PF30 BB, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, bolt-on cable guides, 110mm travel
FEDERBEINCustom Monarch RL with AUTOSAG, air spring, LO and rebound adj., 197x48mm
GABELRockShox Reba RL 29, Solo air spring, tapered alloy steerer, rebound adj., standard QR dropouts, 110mm travel
STEUERSATZ1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
VORBAUSpecialized XC Trail, 6061 alloy, 4-bolt, 8-degree rise, 31.8mm clamp, 6-degree rise, S: 70mm, M: 90, L:100, XL:110mm
LENKERSpecialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 10-degree backsweep, 6-degree upsweep, 31.8mm
LENKERGRIFFESpecialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
VORDERRADBREMSECustom Avid Elixir 3R, hydraulic disc, semi-metallic pad, HS-1 rotor S/M:180mm, Others: 200mm
HINTERBREMSECustom Avid Elixir 3R, hydraulic disc, semi-metallic pad, HS-1 rotor S/M:160mm, Others: 180mm
BREMSHEBELCustom Avid Elixir 3R, tool-less reach adj.
UMWERFERSRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
SCHALTWERKSRAM X9, 10-speed, mid cage, Type 2
SCHALTHEBELSRAM X7, 10-speed, aluminum trigger, w/MatchMaker clamp
KASSETTESRAM PG-1030, 10-speed, 11-36
KETTEKMC X10, nickel plate, reusable Missing Link
KURBELGARNITURCustom SRAM S-1250, 10-speed XC Trail double w/ alloy guard, PF30 spindle, S: 170mm, Others: 175mm
KETTENBLÄTTER36/22, w/ alloy guard
INNENLAGERSRAM PF30, OS press-in bearing, sealed cartridge
PEDALEResin Test Ride Pedals with toe clips, CEN std.
FELGENRoval 29, alloy disc, 26mm wide, 32h
VORDERRADNABESpecialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, QR, 32h
HINTERRADNABENew Specialized Hi Lo disc, 4x-sealed cartridge bearing, 12mm thru-axle, 32h
SPEICHEN
VORDERREIFENSpecialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.3"
HINTERREIFENSpecialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.1"
SCHLÄUCHEUltralight presta
SATTELBody Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SATTELSTÜTZESpecialized 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
SATTELSTÜTZKLEMMESpecialized 7050 hard anodized alloy collar w/ QR, 34.9mm, black
Vergleich zum Stumpy 29er habe ich nicht, bin nur das Stumpy Evo 29er gefahren, welches offensichtlich (140er Fahrwerk, flacherer Lenkwinkel) schon nochmal anders bergab geht.
Dämpferwechsel: Ohne es probiert zu haben, denke ich, dass es nicht so einfach ist. Der Dämpfer wird nämlich nicht über das Dämpferauge geklemmt, sondern hat ein Gewinde in axialer Richtung.
