Mono-Linkrider
Maverick Rider
Have you pressurised it high enough?get well
then I'll have to probably break down again,
although I have done everything according to the manual
Hmm, then I don't know.went to work at maximum,
down worked slowly,
am now at about 8.5 bar
6805, just replaced mine too. Same bearings as those from Shimano BBs btw.Weis jemand die Abmessungen von den Maverick MBit Front Hub Bearing's?
I never had a ML7.0 damper but that hex bolt looks like it keeps the boss with the rod together.Hi
ich hätte eine Frage zum Dämpfer..... das müsste ein ML7.0 sein. Zumindest nach der Wartungsanleitung von Maverick
1. ist das normal das in dem "Attachement Boss" eine Inbus Schraube ist?
ich dachte da kommt die "Adjuster Rod" raus, damit das Drehrad auch eine Funktion hat. Ist das normal???
2. wenn ich den Dämpfer zusammengebaut habe und anfange Luft zu pumpen fliegt der Einstellknopf durch die Gegend.... ich denke das gehört so nicht.... was mach ich falsch???
Gruss
Stefan
You mean the pin that sticks out? That looks like for the rebound adjuster.If I look at the Picture (@Klein-Holgi ) I could see the tip of the adjuster rod looking out of the Boss....
I'd wait until @Klein-Holgi sees this thread and your post, I have no knowledge about the ML7.0 damper.exactly... the silver pin that sticks out.... in my damper there is no pin but a hex screw
Hi
Gruss
Stefan
Da musst Du leider länger warten: Holger macht gerade Forumspause und ich weiß nicht, wie lange die dauert.I'd wait until @Klein-Holgi sees this thread and your post,
Hey now i'm thinking about it: wouldn't it be possible to make a Dual Air DUC this way?Just got a mail back from him, this was his response:
"They use the same base cap on both sides.."
Makes perfect sense to me! AKA: you don't have to touch it or anything, it's only a dummy valve. they did this to cut costs.
Ethan should still have the Palo upgrade kit but don't pin me on it.Hello guys,
Last week I bought unused Klein Palomino 2005 frame with Maverick ML-7 fork and then I read about problems with bushings. I really want to keep it (it would be my first full suspension build ever!).
Could you tell me what I should do in this situation? Contact with Ethan from Maverick and try to get MonoLink? Is it still available?
All best,
BMF
