Klein Palomino Aufbau
Just got a provisional date of when my wheels are done: next Thursday.
fuarrrking HYPED!
Wheels were done a day early, so MY BIKE IS FINALLY COMPLETED!
Pics:
... so da ich nun schon vorletztes WE die rechte Seite zerlegt habe,
ist nu heute die linke dran,
internes Ventil ???
im Handbuch steht nix davon.
jemand ne Ahnung?
Danke
ich werds einfach mal zusammenbauen und schauen ob das Ventil ne Funktion hat...
internes Ventil ???
im Handbuch steht nix davon. jemnd ne Ahnung?
Danke
If you serviced the damper side, you need to pressurize it again. Fill the damper with 95cc's of oil and then cycle it a few times. Then pump it according the tuning chart, I pumped my DUC damper up to 110psi:
EDIT: That looks like the air side.. weird! I'll forward your question to Ethan as I have to ask him a question myself.
Just got a mail back from him, this was his response:
"They use the same base cap on both sides.."
Makes perfect sense to me! AKA: you don't have to touch it or anything, it's only a dummy valve. they did this to cut costs.
DUC owners: if you haven't messed around with your shim stack, you don't know what you're missing! I replaced all the shims in my DUC with 0.1mm thick ones (21/15/12) and it completely transformed my fork. No spiking and VERY supple!
das von meiner frau is nun auch fertig
mehr bilder:http://fstatic2.mtb-news.de/f3/19/1969/1969410-ygsz1t3vd4ij-kleinpalomino1gen_16-large.jpg
und wenn ich mal ne silberne Maverick Nabe finde, zu einem vernuenftigen preis,
dann fliegt der Maveric LRS auch wieder raus
Try asking this guy: http://www.pinkbike.com/buysell/1862406/
I wanted his DUC originally but I dropped out because it looked too bad for me, he might be willing to split the front wheel though.
Is that a The Prodigy - The Experience LP in the background btw?
I need the two bolts for the upgrade Mono Link, which fit for the Palomino-Frame.
Is that possible?
Best regards
Jürgen
Okay, i'm close to ordering my stuff. Do you still need it and how do you want to do it? (should I let Ethan send it to you, or with my stuff that I ordered and that I send it your way when I recieve everything?)
Please order about you,
so he has less labor,
and I have a little more time, for the problems that I had before my service,
too SAG, LockOut not work and on the left side (AIR) rattles sometimes metallic
da ich mir nicht getraut habe, meine vordere Hügi 240 auf Maverick-Achse umzubauen,
habe ich mir vom Sintesi Bazooka einfach die hintere Nabe genommen
SUZUE 12 Loch Disk 12x135 mit eigens angefertigter V2A-Achse
und ich könnte noch einen hinterbau gebrauchen, da ich die Disk-Aufnahme verändert anschweissen lassen möchte, Danke
No lockdown means oil loss/too little oil. Rattling might be a loose negative spring.
It may take a while though before I order all that stuff, had a small setback that has a bigger priority than bike stuff.
