Das ist grob bei Köln, oder? Wie lang hast gebraucht?
und dann ein kurzes steuerrohr, damit der lenker nicht unter das kinn schlägt ;-)Ich brauch eine Truss-fork ?
Na ja, wenn man größer ist, sind die Steuerrohre eh selten zu lang....und als Spacer-Ersatz wäre das ja ideal ?und dann ein kurzes steuerrohr, damit der lenker nicht unter das kinn schlägt ;-)
optisch finde ich die aber auch interessant.
So gar nicht mein Ding... aber schon krassMoustachecycles
Anhang anzeigen 1116239Anhang anzeigen 1116240Anhang anzeigen 1116241Anhang anzeigen 1116243
Story auf theradavist, so lässig ?
Rust Bucket (Bike)…(pre-Moustache):
Low and Slack? No thanks. I made this bike in 2008 at the UBI Brazing course. I had just come off a two-week tour from Tucson, AZ to Mexico’s Barrancas del Cobre where the Surly Cross-Check I was riding had officially fallen out of favor. I wanted to expand on that bike’s mountain bike and touring abilities. I had never owned a 29er. I liked the rolling inertia of the wheel but felt the ones I had ridden lacked the nimble handling of bikes I was accustomed to in the 26 inch days. I made it based on a BB drop that somehow figured on a mathematical proportionality to a 26er with a high-ish BB. It became the original high and tight.
The angles are steep and the fork has an offset and rigidity that’s uncomfortable without a load. Everything was mitered with a file and built with a minimal understanding of fixturing. Having built a fair number of bikes since it amazes me how far this one went. Tours in Baja, an early effort piecing together segments of what has since become the Oregon Timber Trail, White Rim, Colorado Trail. The term “bikepacking” had yet to enter my realm, and I am still a bit reluctant to embrace it in the present. I figured I’d ride this bike to trailheads, take my panniers off and make camp, then ride the trails.
Sehr schön. Wie ist bei dir der Abstand Kurbel Rechts zu Kettenstrebe? Ich hatte da kontakt im Wiegetritt. Habe jetzt die Kurbel an der Stelle ein bisschen abgefeilt und jetzt ist Ruhe...Nachdem mein Plastikfully den Geist aufgegeben hat, hab ich mir wieder was aus dem Material des Vertrauens geholt ;-)
Bikeromantik in der Ewigen Wand...
Hi, Habe die 2019er GX Kurbel montiert (Q172)mm, viel Platz ist nicht, aber Kontakt hatte ich bis dato noch nicht.Sehr schön. Wie ist bei dir der Abstand Kurbel Rechts zu Kettenstrebe? Ich hatte da kontakt im Wiegetritt. Habe jetzt die Kurbel an der Stelle ein bisschen abgefeilt und jetzt ist Ruhe...
Jetzt mit noch mehr Stahl.
Ja die Kurbel ist nicht das Gelbe vom Ei. Die lag halt noch in der Kiste. Ich liebäugle ja mit der RMC Kurbel in Silber. Muss nur über meinen Schatten springen und die abartigen Versandkosten hinnehmen.Die M665 Kurbel würde ich noch tauschen oder ggf komplett schwärzen und die Felgendecals entfernen.....das war's dann aber auch schon
