Don't find any pic that fast, but it's possible to have break routing on the same side.Hmmm that's not very good then ☹
Danke, ja genau, hatte auch noch den von unleazhed im Auge. Leider kann ich das Rad momentan nicht ergiebig testen, da ich noch eine Mittelhand-Bruch auskurieren muss. Schrauben ging zum Glück!Ist das vorne das Mudhugger Short Race?
Und berichte mal bitte wie der Jade X läuft. Schöner Aufbau!![]()
I'll be using AXS gears so rear brake will go on the Right side, dropper will go on Left side. Not what I intended as when I placed order I thought I could put 2 cables either side. Bit of a design fail by @last-bikes.com really, as it not going to look nice. Had I known this before placing order I probably wouldn't have bothered, it's taken the edge off the excitement of new frame nowDon't find any pic that fast, but it's possible to have break routing on the same side.
If you leave the little metal guide at the cable entrance off there should fit 2 cables. just have to use a zipp tie or something like that to keep them from rattling. but i havent tested it myself.I'll be using AXS gears so rear brake will go on the Right side, dropper will go on Left side. Not what I intended as when I placed order I thought I could put 2 cables either side. Bit of a design fail by @last-bikes.com really, as it not going to look nice. Had I known this before placing order I probably wouldn't have bothered, it's taken the edge off the excitement of new frame now
Will have to put up with it until I can get an AXS dropper, they are not available until 2022![]()
Wie keine Einkehraka Haldenhonk bleibt beim Angstschleichen nicht mehr so leicht im Wurzelpuff hängen.
M.
ich auch nicht, scheint was nicht zu stimmen…Komme nur ich seit gestern nicht mehr auf die Last Homepage?
das Loch könnte man aber mit etwas Fingerspitzengefühl erweitern. Dremel oder Feile und ruckzuck isses UK kompatibelRight: nur ein Kabel![]()
Looking at post a while back, not sure there is room for 2 cables.how to expand? For two cables?
That won't work even with a sure instinct ...![]()
Why not talking to Last Bikes about this issueLooking at post a while back, not sure there is room for 2 cables.
Is the internal routing the same size left and right and just the exit smaller?
I looked for a post a while ago and am not sure if there is room for 2 cables.
Is the internal guidance left and right the same size and only the exit smaller?
I did....................Why not talking to Last Bikes about this issue
Maybe they already have a solution...
OK, that's a bummerI did....................
the right size has only space for one cable. The 2 whole insert only fits on the left side.
Best regards,
Michael
As I said a bit of a design fail/fault
Just ask them to send two inserts for left side? Or take the one for left side for right side (did you order raw? open up the hole in the frame a bit...) or print something?OK, that's a bummerFrom your point of view, this might be a design fault, but for the mayority of Last Customer not
But I'm sure, there is a solution for that. Be creative!
Die Inserts/Öffnungen sind doch unterschiedlich groß, so wie ich das verstanden habe...Just ask them to send two inserts for left side? Or take the one for left side for right side (did you order raw? open up the hole in the frame a bit...) or print something?
Deswegen die Frage ob raw.Die Inserts/Öffnungen sind doch unterschiedlich groß, so wie ich das verstanden habe...![]()
Na dann soll er den Dremel mal aus der Ecke holen.Deswegen die Frage ob raw.
Da hätte ich ich kein Problem damit rechts "aufzumachen". Dann da das linke insert rein und für links eins mit nur einem Durchgang drucken
Auf keinen Fall in den Rahmen bohren...Deswegen die Frage ob raw.
So schmallippig der Post ist, scheint da aber was im Argen zu sein...ich auch nicht, scheint was nicht zu stimmen…Anhang anzeigen 1304091
Jetzt wo du es erwähnt hast, rate ich doch besser davon ab!Auf keinen Fall in den Rahmen bohren...
Die Löcher haben doch ne Aufkantung bzw. Verstärkung, die hättest du bei einer Erweiterung nicht.
Das wird dir LAST niemals erlauben.
Uhh, Risse gebildetJetzt wo du es erwähnt hast, rate ich doch besser davon ab!
Hatte mal ein Canyon Spectral, bei dem diese Abkantung am Ausgang für die Dropper gefehlt hat.
Da haben sich dann Risse gebildet. Wurde zwar getauscht der Rahmen, aber war dann beim neuen Rahmen wieder ohne Abkantung. Somit war das Thema Canyon dann damals beendet für mich![]()
Vielleicht kommen die Jungs ja dann mal dazu mein bike aufzubauenich auch nicht, scheint was nicht zu stimmen…Anhang anzeigen 1304091
Bist du nicht selbst SchrauberVielleicht kommen die Jungs ja dann mal dazu mein bike aufzubauen![]()
Nein, nicht direkt. Ich habe mir ein konfiguriertes bike bestellt, da mir die Teile einzeln zu teuer sind. Zudem finde ich, dass es bei Last ja super geht mit dem Baukastensystem sich sein Rad passend zu konfigurieren. Aber ich werde den Vorbau und Lenker noch tauschen sowie ein, zwei Kleinigkeiten ergänzen… Im Prinzip hätte ich aber schon Bock selber etwas aufzubauen!Bist du nicht selbst Schrauber![]()
