Anscheinend sind die Händler Kataloge schon verschickt.
Interessantes aus einem englisch-sprachigem Forum:
DM-SC schrieb:In the '05 catalog that I saw over the weekend, the SJ Pro 120 is speced with a Manitou Minute one, not a Fox Talas. It also listed full XT hydro disc brakes, XT (front uses a stout hub)/Mavic XC717 wheelset, Thomson seatpost, XT/XTR drivetrain. It comes in silver ano.
The SJ Expert 120 is pseced with a Fox Talas, Avid Juicy 7 brakes, Mavic 317 rims, LX/XTR drivetrain and comes in Black ano.
The SJ Expert 100 is nearly identical to the '04 except that the it's a darker shade of red.
There's a SJ Comp 100 and a base SJ along with a women's specific SJ 120 & SJ 100.
The base Enduro and Enduro Comp still use a '04 style frame.
The Expert (Fox 36 R Talas100-150 with a 5th Element shock, Avid Juicy 7 8"/6" brakes) is blue
The Pro (Fox 36 RC2 with the same 5th Elemnet, XT 8"/6" hydro brakes) is Charcoal gray.
The SX has 4.2" rear trave and is red/black (Fox 36 R Talas100-150 w/20mm thru axle and a 5th Element shock, Hayes HFX Mag 6" brakes).
The SX Trail has 6" rear travel and is brown/black (Marzocchi 66R single crown w/20mm thru axle and 5th Element Coil shock, Hayes HFX-9 hydro disc with 8" rotors)
DM-SC schrieb:The catalog I saw did not list a SJ Pro 100, only the Expert, Comp and base models in 100mm travel versions.
The color of the SJ Pro 120 looks very close to the silver ano they used on the '04 Anniversary SJ. It may not be exact, but it looks pretty close. Based on the pictures in the catalog, at first glance, it's going to be hard to tell the 120 from a 100. The geometry table listed the stand over and BB hieghts as gaining only a quarter of an inch (?).
. Aber ich könnte mir vorstellen, daß die Grundkonstruktion, egal ob Deore, bisheriges LX oder XT, so ziemlich gleich ist. Das XT Innenlager hat z.B. ne hohlgebohrte Achse, und ist so 10g leichter als das LX. Dann könnt ich mir noch vorstellen, daß beim LX und XT vielleicht n bischen besseres Material verwendet wird (gegenüber Deore), und/oder mit geringeren Fertigungstoleranzen gearbeitet wird. Ist aber alles nur Spekulation. Müßte man sich angucken, aber genau das können ja die Leut mit den knarzenden Innenlagern tun
Da lassen wir uns ma überraschen.
Das wäre ja zum
. Kette + Antrieb pflegen ist zeitaufwendig
